Phanteks Halo Control Issues?
Solved by W-L,
34 minutes ago, Jason_Tan_ said:So I am interested in picking up some of those new phanteks halos fan frames, but I don't have a motherboard with asus aura (or any equivalent). I was curious if I could control them in any way and if phanteks sells some sort of way for me to control them using a module or something of that sort? Thanks in advance!
The phanteks halo units not lux since it can interface with aura sync are going to operate the same as the SMD 5050 LED strips so you can get cheap RGB LED controllers and wire them up to it using the phanteks adapter.
