It won't have no pins in the top for the power supply connection. If you still can't tell post a picture or link to the card you want to install
I7 7700K @5.0ghz, Asus Z270-P, Corsair H115i, hyperX 16gb, Asus duel 1070, Nzxt H440
https://uk.pcpartpicker.com/list/ZTsYD8
https://linustechtips.com/topic/842187-upgading-a-pre-built-pc/#findComment-10511712
10 hours ago, Skatester07 said:
That one does not need any extra power from cables. Recommended PSU is 300w, but 240w should be enough as long as you do not do any OCing.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/842187-upgading-a-pre-built-pc/#findComment-10513214
13 hours ago, Skatester07 said:
The PSU is enough for this card as it draws its power directly from the PCIE slot on the motherboard.
https://linustechtips.com/topic/842187-upgading-a-pre-built-pc/#findComment-10513674
