Is there any single GPU graphics card that gives 60+ fps in Battlefield 4 at 1440p with max settings?  Perhaps a 780ti Classified or 290X with Mantle, are they the only options?
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/84123-graphics-card-for-bf4/
I would recommend going with the 780ti as the RX 290 are having problems at the moment
I'd be waiting to get the 290X non reference cards so hopefully problems won't persist then and drivers will have matured slightly.
https://linustechtips.com/topic/84123-graphics-card-for-bf4/#findComment-1145325
Go with either the R9 290 or the GTX 780Ti depending on what your budget is. The R9 290 is the better performer for the price but the 780Ti is the most powerful card you can get for gaming at the moment.
Intel Core i7-8700K @ 4.8GHz | Corsair H110i GTX | EVGA RTX 2080 XC | Asus ROG Maximus XI | Intel M.2 nVME SSD 1TB | Samsung 850 EVO 2X2TB | 32GB G.SKILL Trident Z 3200MHz CL14 RAM | EVGA SuperNova GS 1050W | Kept cool & quiet in a Fractal Design Define R5 Window with all Noctua fans
https://linustechtips.com/topic/84123-graphics-card-for-bf4/#findComment-1147236
I'm going to wait and see what Mantle can do.  If a Matrix 290X and Mantle don't outperform an 780ti Classified then I'll go for the 780ti.
https://linustechtips.com/topic/84123-graphics-card-for-bf4/#findComment-1147259
