Introduction
I have recently run into some difficulties with my year and a half old system (specs below). It started as some odd issues with Windows the search function where it would close after a few seconds of being open. I tried the suggestions online but got nowhere so I refreshed my machine. This actually caused more problems, mainly with the graphics, so I completely reinstalled windows drivers etc. Now all of those issues are gone but now I am getting various bluescreens all of which appear to be tied to memory and I am getting random program crashes for various programs.
However, the odd part of this, and the reason I haven't just gone out and replaced my memory, is that Memtest86+ has not picked up any issues with my RAM with over a dozen passes. Because of this, I am somewhat concerned that the issue is actually some alternate hardware issue (say the motherboard) and I am looking for some guidance on how I should go about moving forward.
The System
Operating System: Windows 10
Motherboard: MSI x99s SLI Plus
CPU: i7-5820k
Memory: G.Skill DDR4 3000 8GBx2
GPU: MSI 980ti
HDD: WD Black 2TB
SSD: Samsung 850 EVO 250GB
PSU: EVGA SuperNOVA 750 G2
The BSODs
The BSODs I have been getting are varied but all appear to be memory related. I have attached the minidump files below. These are never BSOD loops and only occur about once every 2 days but that's regular enough to cause serious concern obviously.
Windows Memory Diagnostic
Unlike Memtest86, WMD has returned that there are hardware issues both times I have run it. However, I do not know how to read the information so any assistance in that regard would be appreciated:
Log Name:      System
Source:        Microsoft-Windows-MemoryDiagnostics-Results
Date:          9/30/2017 16:24:13
Event ID:      1102
Task Category: None
Level:         Error
Keywords:
User:          SYSTEM
Computer:      DESKTOP-1CFA8QE
Description:
The Windows Memory Diagnostic tested the computer's memory and detected hardware errors. To identify and repair these problems, contact the computer manufacturer
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-MemoryDiagnostics-Results" Guid="{5F92BC59-248F-4111-86A9-E393E12C6139}" />
    <EventID>1102</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime="2017-09-30T23:24:13.623379300Z" />
    <EventRecordID>3644</EventRecordID>
    <Correlation />
    <Execution ProcessID="4996" ThreadID="5024" />
    <Channel>System</Channel>
    <Computer>DESKTOP-1CFA8QE</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <UserData>
    <Results xmlns="http://manifests.microsoft.com/win/2005/08/windows/Reliability/Postboot/Events">
      <LaunchType>Manual</LaunchType>
      <CompletionType>Fail</CompletionType>
      <MemorySize>16284</MemorySize>
      <TestType>10</TestType>
      <TestDuration>78</TestDuration>
      <TestCount>12</TestCount>
      <NumPagesTested>4167370</NumPagesTested>
      <NumPagesUnTested>1230</NumPagesUnTested>
      <NumBadPages>1</NumBadPages>
      <T1NumBadPages>0</T1NumBadPages>
      <T2NumBadPages>0</T2NumBadPages>
      <T3NumBadPages>0</T3NumBadPages>
      <T4NumBadPages>0</T4NumBadPages>
      <T5NumBadPages>1</T5NumBadPages>
      <T6NumBadPages>0</T6NumBadPages>
      <T7NumBadPages>0</T7NumBadPages>
      <T8NumBadPages>0</T8NumBadPages>
      <T9NumBadPages>0</T9NumBadPages>
      <T10NumBadPages>0</T10NumBadPages>
      <T11NumBadPages>0</T11NumBadPages>
      <T12NumBadPages>0</T12NumBadPages>
      <T13NumBadPages>0</T13NumBadPages>
      <T14NumBadPages>0</T14NumBadPages>
      <T15NumBadPages>0</T15NumBadPages>
      <T16NumBadPages>0</T16NumBadPages>
    </Results>
  </UserData>
</Event>
092217-8328-01.dmp
092617-7328-01.dmp
092717-7281-01.dmp
092917-5281-01.dmp
093017-8281-01.dmp
https://linustechtips.com/topic/841127-difficulty-diagnosing-memory-issues/
So with memory, its usually 1 or 2 things, the RAM itself, or the CPU, since it houses the memory controller. Very very rarely is it ever the motherboard that is the problem in these instances. What I would recommend doing is try removing your overclock on your CPU and testing for an extended period of time to see if you get the errors or crashes.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Quote
So I have no overclock on my CPU currently though I am using XMP on the memory. Would it be worthwhile running without that for a while to see what happens?
definitely.
Community Standards
"Beast Mode"
