So today i bought an elgato hd60 pro , i installed it fine and when i plugged in the hdmi the screen was acting like two screens instead of of one , so i went into display settings and changed it from its default to only one after doing so my monitor went black and said dvi signal lost  , so basically to get my elgato to work i need to plug the hdmi into the graphics card  and into the in port on the card but doing so black screens me so i cant do anything to revert the changes i made any help on to fix this
https://linustechtips.com/topic/840784-dvi-help/
EDIT" so here is how i have things setup i have my dvi going from my monitor into my graphics card and i have my elgato installed i take the hdmi and plug it into the out port on the gtx and plug it into the in port on the elgato doing this after i screwed the settings up black screens the monitor and i can only use the monitor if i unplug the hdmi
edit " think of the elgato as a second monitor and how i can revert it back
https://linustechtips.com/topic/840784-dvi-help/#findComment-10496080
By the sounds of this instead of setting the displays to duplicate which is what you would want you set it to 1 only or 2 only (Whichever it may be). Does your monitor have a HDMI in? I am assuming not and I don't know how to change it but that sounds like whats happening.
I have seen before HDMI to DVI that you could use to go from the out on the Elgato (Which I assume it has) and that is what I think would be the easiest setup because then it would always record exactly whats on the monitor which is what it sounds like you are trying to do.
Demeter - Gaming Tower: CPU: Intel Core i7 8086k @ 5 Ghz All Cores Motherboard: ASUS Prime Z370-A RAM: 4x 8 GB G.Skill Ripjaws V @3200 Mhz GPU: EVGA GTX 1080 FTW Boot Drive: 500 GB Samsung 960 EVO NVMe Data Drive: 1 TB WD Blue SN550 NVMe Game Storage: 2x 4 TB Seagate Barracuda HDD Case: Lian Li O11 Dynamic PCMR Edition CPU Cooler: Corsair H100i RGB Platinum Make & Model: Custom Built
Artemis - Laptop: CPU: Intel i9 8950HK @ 2.9 Ghz 6 Cores RAM: 32 GB DDR4 GPU: AMD Radeon Pro Vega 20 / Intel UHD Graphics 630 Storage: 1 TB Drive Make & Model: Apple MacBook Pro 15-inch, 2018
https://linustechtips.com/topic/840784-dvi-help/#findComment-10496103
so whats happening with me is after i switched it from dup to 1 it went black with the  elgato plugged in now when i plug the hd60 pro in the screen keeps going black and losing dvi signal and i have no clue on how to revert it back so i can fix it @Megagaming073
https://linustechtips.com/topic/840784-dvi-help/#findComment-10496116
Hmm... As far as I know, you somehow have to see the output on the Elgato to navigate back to the settings. Is there a TV or something you can use temporarily until you can get it fixed?
https://linustechtips.com/topic/840784-dvi-help/#findComment-10496165
Just now, Verse^ said:
What I did is I'm going to system restore back to before I messed it up and hopefully can fix it from there @Megagaming073
Okay try that and let me know how it goes from there. (I won't be responding again until tomorrow morning since it's 12:30 AM for me and I need sleep) So best of luck until then!
https://linustechtips.com/topic/840784-dvi-help/#findComment-10496171
7 hours ago, Verse^ said:
It didnt work but goonight man @Megagaming073
Okay. I didn't think so but it was worth a shot. Do you have any screen with a HDMI in? If so you can use that to see the output on Elgato and work from there. Other than that I'm not sure how to reset the display settings.
https://linustechtips.com/topic/840784-dvi-help/#findComment-10496870
