Help! Please!
Go to solution Solved by Cyberspirit,
@sivertholmvik Well bad luck man. Why on earth did you not get at least 103 layers of protection on that thing?
A case and a skit at least for such a disgustingly expensive phone?
The screen is dead for sure.
Hey, i just dropped my new s8+ on the concrete, about waist hight. But now the screen is cracked all over the place and the display has killed it self. Blacks are displayed as green and epileptic spasms and stuff like that. Is the display dead or just a loose display ribbon.
https://linustechtips.com/topic/839614-help-please/
I'm guessing the warranty is still valid...
bad luck mate.
https://linustechtips.com/topic/839614-help-please/#findComment-10483829
Just now, sivertholmvik said:
You think? I have insurence on the phone but i need to wait 3 months for them to fix it for a lower cost or just replace the whole phone.
You're the one who dropped it mate, also I'm pretty sure it's an expensive repair anyway because of the curved glass/screen so you're probably gonna need a new phone anyway.
https://linustechtips.com/topic/839614-help-please/#findComment-10483842
4 minutes ago, sivertholmvik said:
Its soo dumb... Had a nexus 5x for 3 years and it never cracked. Bought a s8+ for 900 f'ing dollars and dropped it once and the whole thing killed it self....
https://linustechtips.com/topic/839614-help-please/#findComment-10483845
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/839614-help-please/#findComment-10483849
Had a case and screenprotector on it but it landed like 45 degrees face down on the corner. Scuffed and bent the frame into the glass...
https://linustechtips.com/topic/839614-help-please/#findComment-10483856
That's just bad luck. I smacked my phone on the ground (face first) with a case that had like 1 milimenter of space "extra" and didn't crack.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/839614-help-please/#findComment-10483868
@sivertholmvik That thing does look pretty good and it allows you to show off the skins so i'll probably get one as well.
Good luck with the repairs man. Be more careful next time with a phone like that.
https://linustechtips.com/topic/839614-help-please/#findComment-10483897
yee.
thanks. yes i will.
i can post some pics of the phone now
https://linustechtips.com/topic/839614-help-please/#findComment-10483913
