Decent Audio Under $25?
do you need a DAP, earphones, headphones, earbud or IEM, over ear or on ear?
but for that budget you're probably better off looking on head-fi's chi-fi threads.
Intel i5-6600K@4.2GHz, 16GB Crucial DDR4-2133, Gigabyte Z170X-UD3, Be quiet shadow rock slim, Sapphire RX 480 Nitro+ OC, Fractal design Integra M 550W, NZXT S340, Sandisk X110 128GB, WD black 750GB, Seagate momentus 160GB, HGST 160GB
https://linustechtips.com/topic/838955-decent-audio-under-25/#findComment-10476791
For headphones, you can't go wrong with the Skullcandy Navigator for $25.
If you just want earbuds, then the $6 VE monk will blow your mind.
If you want earphones, then check out the KZ ZS5 under $30. The KZ ATE is also solid under $10. Also look for the KZ ZS3 or ZST around $10 to $20 as well. A lot of KZs, I know.
If you want desktop speakers, then the Logitech Z200 is shockingly good under $30.
And....that covers everything!
You can find all of these things on Amazon.
https://linustechtips.com/topic/838955-decent-audio-under-25/#findComment-10477687
