I had a USB3.0 external HDD
When I plug in my HHD into the 3.0 port on the front of the case
It keeps installing and drop out
but when I plug into a 2.0 port on the front of the case, it doesn't have any problem
Moreover, when I plug into a 3.0 port on the back of the motherboard, it also doesn't have any problem.
After that, I try to plug in a USB 2.0 flash drive into the 3.0 port on the front of the case, it also works.
So, why I cant use the HHD on the 3.0 port on the front of the case????
https://linustechtips.com/topic/838694-problems-with-the-usb-30/
usb 3 needs both the chipset drivers and usb 3 drivers installed
the frontpanel should be usb 3.0 compatible too and connected to ur mobo
make sure that the front panel usb isnt set to usb 2.0 mode or legacy mode
it could also be a cable length issue
the front panel requires a extended cable from the motehrboard to the front panel already, if the distance from motehrboard to device is too long, usb loses its signal strength and it can cause issues ( u could try an super short cable for the hdd )
Maybe the wiring of the front USB 3's or the header for the USB 3 isn't working as intended.
Desktop benching:
7
I am using the gigabyte X370 and view31 case
 make sure that the front panel usb isnt set to usb 2.0 mode or legacy mode => how to check???
motherboard usb settings ( there are settings for the front panel aswell in the motherboard )
however the frontpanel can be in a different location then the standard usb settings since it runs off a different chip
I just checked and can't find any USB settings.
5 minutes ago, spitfire0o0 said:
Gigabyte GA-AX370-Gaming 5
mb_manual_ga-ax370-gaming5_e.pdf
page 32\
u can add some volt to the front panel and test if that works , there should be a legacy mode , usb modes for frontpanel somwhere too :P
page 32\
I just tried but still don't work.
u have legacy usb support enabled, disable or set it to auto
aswell u have only set the voltage compensation for front port 1, port 2 is still default :)
u can also try disabling usb mass storage driver support, ( can cause issues with external drives too )
if u connected it to port 2 then it wouldnt have made a difference there
I tried again and still not working
I don't know when I plug into the USB2.0 just work fine but not the 3.0IMG_20170924_234437299.thumb.jpg.a2e6410e6b29f04ec636aea0dfeeb359.jpg
3 minutes ago, Valkyrie Lenneth said:
that is really strange to be honest, it  could even be an issue with the usb3 connector on the motherboard , the case pcb to the usb ports and other stuff o,o if that stuff doesnt fix it its really really strange ._.
if those had problems, it will not work when I plug in the USB 2.0 flash drive too???
but the USB 2.0 flash drive just works fine:( really strange
it could be that the 2.0 works fine but the 3.0mode is fucked ( 2.0 mode is basicly legacy of 3.0 )
u can always force disable legacy and see if taht works , however it could end up meaning ur keyboard wont be detected in the bios ( rarely happens only tho )
5
it could be that the 2.0 works fine but the 3.0mode is fucked ( 2.0 mode is basicly legacy of 3.0 ) <<<<this means the mobo had broken??
i think the front ports just dont support hot swapping on the usb 3.0 mode
or a setting ;c
i dont think the board is broken or defective at all
