Hi. I just got my online ups, prolink 802-ERS 2KVA/1800W. Any suggestions on the frequency range. By default this are the settings. I am not really comfortable with max voltage set at 264? and min at 170? Any recommendations on this? Or should I just leave this by its default settings? Btw, I am from the Philippines with a 220V/60Hz AC voltage/freq.
I.) R9 5950X | LF III Pro 360 | X570 Aorus Master rev1.0 | 64GB Gskill 3600Mhz (B-die) | 2TBx3 M.2 | 500x2 850 Pro | 1TB 860 Evo x 2 | Seasonic 1000W Ti | RTX 5080 Astral
II.) R9 5900X | U12A | X570 Aorus Master rev1.0 | 64GB Dominator 3466Mhz (B-die) | 2TBx3 M.2 | 2TB WD Gold | Seasonic 1000W Ti | 6800XT Nitro+ SE
III.) Relay Server: E5 2697Av4 | D15 | X99 E WS 3.1 BIOS 4001 | Micron DDR4 RDIMM 2400Mhz | P620 | 6x 2TB 970 Evo Plus | 12x12TB HC520 | Define 7 XL | Seasonic Platinum 1300W
IV.) TrueNAS: 3900X | NH D12L | X570D4U-2L2T | Corsair LPX 128GB DDR4 | Arc A380 | 12TB x8 HC520 | Intel Optane x2 boot drive | 4x 500GB 870 Evo Plus
V.) R7 5700X | LF III Pro 240 | X570i ROG | 32GB Team Create 3600Mhz (B-die) | 2x2TB M.2 | Silverstone 800W Platinum Extreme SFX
https://linustechtips.com/topic/837318-online-ups-setup-help/
