Hello guys , how do you rate this build ?
I know that PSU / SSD isn't the best there is but will it do the work ? it comes pre-build like 200euros cheaper if i were building it my self with same parts.
Long story short , this builds parts :
PSU - AMD Ryzen 7 1700
MOBO - MSI B350M MOTOR AM4, 4xDDR4, 4xSATA3, HD Audio, 2-Way AMD® CrossFire™
RAM - ADATA XPG DDR4 8gb 3000Mhz CL16 1.2V with aluminum heat spreader
SSD - Silicon Power S55 SSD 240GB 2.5" SATA III 6Gbps 550/450MB/S
GPU - Zotac Geforce GTX 1070 Founders Edition 8GB Engine Clock (Boost):1683 MHz, Memory Clock: 8 GHz, 3 x DisplayPort 1.4, HDMI 2.0b , DL-DVI
CASE - X2 Spitzer
PSU - Inter-Tech Energon 650W 82% Efficiency at typical load, EPS AC 220-240V, 50/60Hz, DC 3.3/5/±12V
it comes in total for 999$
https://linustechtips.com/topic/836290-pre-build-pc-question/
It's not a bad deal for a prebuilt but the power supply is hot garbage. I'd try and replace that at the very least.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/836290-pre-build-pc-question/#findComment-10447932
yea the PSU looks like garbage to me ;) , i was thinking maybe i should just save and get ryzen 5 1600 with 1060 6gb instead hmmm...it's fairly like 200 euros different hmm...i know this build would last me ages heh :D
https://linustechtips.com/topic/836290-pre-build-pc-question/#findComment-10447946
Just now, seon123 said:
Bad BIOS, crappy VRMs. For a 1700, you want a decent board, especially when you're overclocking.
i dont think i ever plan to overclock stuff  , i dont have any clue how to do that , and dont want any aditional stress on the computer it self  :D
https://linustechtips.com/topic/836290-pre-build-pc-question/#findComment-10447972
Then why get a B350 board in the first place? Why not save the money and get an A320 board for cheaper?
Overclocking is easy, and you should do it. And also get a decent board
https://linustechtips.com/topic/836290-pre-build-pc-question/#findComment-10447978
i guess you havent read my tittle , it's PRE-BUILD PC , i might contact the official seller , they might replace some parts with the one's i want but i'm not sure it's going to happen , thats why i'm asking here about this PRE-BUILD PC :)
https://linustechtips.com/topic/836290-pre-build-pc-question/#findComment-10447984
it's like 200 euros cheaper pre-build , then if i buy the same exact parts so yeah xD
https://linustechtips.com/topic/836290-pre-build-pc-question/#findComment-10447989
