LED recommendation for inwin 509
currently im using 3 strips from a deepcool rgb kit. and they barely lighten up the case its super dark. the glass is super dark tint and thick, when the panel is off the case the lights are of normal brightness, ive been fighting this for about 1.5 months now and ive given up and looking to find a brand that can be used in this case.
case is inwin 509
Faith: WIP
Cpu: intel 6700k
RAM: g.skill ripjaw v 3200mhz 16 18 18 38 2n 32gb 4x8gb
MB: Asrock extreme 7+
GPU: GTX 1080 TI Poseidon Platinum Asus ROG
PSU: Cougar 1050W 80+ gold
Case: IN WIN 509 ROG [ black red ]
Cooling: Barrow Fittings, Block, 360mm x 60mm rad, 18w d5 pump, 210 res, EK blood red premix. Poseidon GPU block
SETUP: BenQ 27" 144hz|BenQ 28" 1080p VA 60HZ|Corsair Strafe RGB|Razer DeathAdDer Chroma|ATH IM70|E10k Olympus 2 amp|DX Racer King
https://linustechtips.com/topic/836244-led-recommendation-for-inwin-509/
3 minutes ago, CableMod said:
@vESP check out the RGB/W WideBeam LEDs that we offer here at CableMod. You'll definitely see through that glass with ease. :)
:P first cables now lights. Now Do u sell UV?
Faith: WIP
Cpu: intel 6700k
Just now, CableMod said:
@vESP we have UV and RGB/UV hybrids! :)
is that cable uv?
Faith: WIP
Cpu: intel 6700k
@vESP here's a higher quality photo not off my camera, uploaded the wrong one initially! :)
thats, uh, wow. ok. thats better then id have hoped. now is that a white and black sleeve? sorry for being so confused, just stunned
Faith: WIP
Cpu: intel 6700k
case is inwin 509
I would suggest to double up the LED strips if the tint is just a little heavy for the light to get through to a level that is something you like.
