USB audio interface which one do i get
i am gonna use it for avid pro tools and later on buy some xrl mics i am gonna buy monitor speakers.
i only saw one has the monitor outputs ports in the back scarlet 18i8 do the others have this port for monitor speakers or do i need to use xrl vs line cable in the back  and not sure what the diffrences
https://linustechtips.com/topic/836174-usb-audio-interface-which-one-do-i-get/
All the Scarlett interfaces have their monitor outputs in the back...
26 minutes ago, patriciadiaz1919 said:
i ask because in the picture why only this model it has it with letter label not the other
Numbers one and two are monitor outputs, also called line outputs.
Image result for 2i4
Image result for 2i2
Image result for 6i6
Image result for 18i20
