9 hours ago, RageAx said:
I need help deciding between these two laptops:
-Asus ROG GL502VM (8GB RAM version)
-Asus ROG Strix GL753VD
I will use them for gaming and for work
Neither options look good for me.
What's your budget?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/835606-need-help-deciding/#findComment-10443171
1 minute ago, RageAx said:
My budget is up to 1200€. I'm buying from Europe, more specifically Slovenia.
Tell me, why don't these laptops look good to you?
Check mysn.de web site
xmg P507 2016 (clevo p650rp6) for 1099 euros without ssd/hdd
https://linustechtips.com/topic/835606-need-help-deciding/#findComment-10443956
The thing is, I cannot pay it all at once, since i'm a student. I need to pay it in installments so in reality I belive those are my only two options :(
https://linustechtips.com/topic/835606-need-help-deciding/#findComment-10443974
GL502VM suffers from heat issue
GL753VD suffers from a loud fan
Both laptops uses mediocre chassis quality
Get the Dell 7567, solid choice
Desktop specs:
https://linustechtips.com/topic/835606-need-help-deciding/#findComment-10444074
