Hi, whenever i try to restart my PC is goes into a boot looping cycle but if i turn the PSU off and press the power button then turn the PSU back on it posts normally. any advice/ help would be appreciated.
Specs (if needed)
mobo- Gigabyte X58-USB3
CPU- intel X5650 overclocked to 4ghz (the overclock does not change the issue)
RAM- 16gb Patriot Memory DDR3. ( 2 8gb dimms)
Graphics card- gtx 1050
PSU- corsair CX430
https://linustechtips.com/topic/834824-restarting-issue/
430W seems a bit weak for a system for that calibre. I mean it'll probably minimally meet the requirement wattage, but that's never recommended.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/834824-restarting-issue/#findComment-10433551
i used to have a 500w but the fan died. I currently don't have the money to upgrade PSU do you think that could be the problem?
https://linustechtips.com/topic/834824-restarting-issue/#findComment-10433580
