I just received my R2 Midi and the power button is a little loose and wobly. Can anyone else with this case tell me if this is normal or do I have a defective case?
Thanks
I have the same case. Mine is very little wobly, but if you pc turns on i dont see the problem. :D
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/83472-arc-midi-r2-power-button/#findComment-1137145
Mine is pretty sturdy, might want to get that replaced. Fractal's customer service is top notch. I recently broke my front audio ports when i tripped over my headset and they sent me a replacement without any hassle free of charge.
Arc Midi R2 | Asus Maximus VII Hero | Intel i5 4690k | Asus GTX 970 Strix | Corsair H80 | Crucial M4 128gb | 8gb 1333 Mushkin Silverline | EVGA G2 750
Filko Ninja TKL Cherry MX Black | Mionix Naos | Fiio e10k | Edifier S330D | Sennheiser HD558 | Blue Snowball | Asus PA238QR | Samsung BX2250
https://linustechtips.com/topic/83472-arc-midi-r2-power-button/#findComment-1142405
