Deus ex mankind devided performance problems
Go to solution Solved by Praesi,
There is no need to reinstall the OS. My bet is DX12.
Hi all!
I hope somebody can help me with my problem since ive been losing my mind for the past month trying to fix the annoying issuses. So the problem i am getting is in deus ex and rottr. Both games run smoothly (above 60fps), then all off a sudden just stutter terribly for about two seconds then back to normal. It is more common in deus ex tho. Im running both in dx12 with no aa.
Specs:
Ryzen 1600x @3.8ghz 1.25v, newest bios
Corsair vengeance 2x8gb rgb @2933mhz
Cm g650m bronze power supply
Asus x370 pro motherboard
Gtx1080 auros 8gb stock
Installed on samsung 850 evo 250gb
Cpu temps max 52 celsius
Gpu temps max 65 celsius
Tried the folowing:
-Reinstalled win 10 64 bit like 4 times
-newest and oldest drivers
-only the essentials instaled (drivers and updates)
-power plan ryzen balanced, gpu max performance and all that stuff
On a side note bf4, bf1, forza horizon 3, project cars, gta 5 all run without problems, normal scores while testing with cinebench, fire strike, heaven benchmarks, online pc bench tests show outstanding results
Plus ive read somewhere that this could be an ryzen-nvidia optimisation issue is that true?
Any help would be really grately appreciated!
https://linustechtips.com/topic/834481-deus-ex-mankind-devided-performance-problems/
Use dx11
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
1 hour ago, Rackooo said:
That lowers the famerate significantly on ryzen (at least in rottr)
does it lower it below 60fps?  and it is more stable, like no more dips?
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
Yes in tomb raider it does go below 60 in some cases i believe that is a known issue with ryzen and dx11 in tomb raider. But with dx11 i see no more stutters just lowered fps
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
