cable management Help with cable management
8 minutes ago, Moeplazz said:Hey guys, I'm nearly done with my build. These are the current specs
- Amd ryzen 5 1600 CPU
- MSI A320M GRENADE Motherboard
- Shitty graphics card, won't even mention.
- 550W Corsair power supply, non modular
- Fractal design focus g mini black case
So the issue is that my PSU is not fully modular and it has molex cables and I'm finding it difficult to cable managet from the back and there's a also a fan cable port near the graphids card which is annoying. Any cable management tips for my case?
Pull all the unused cables out the side through the large hole between the psu and drive bay. Pull them all the way out and put a tie/strap around the bunch of them where they exit the hole. Collect all the ends together and put another tie just below the shortest. Run the cable collection up beside the case interface cable(s). Use ties at the bottom and the top. Fee the excess into the External drive bay.
