9 minutes ago, condog209 said:
Got new motherboard aorus  GA-AX370-Gaming k7 and I can't find where this cable for led goes ( got q part of it plugged in
150530159587489733332.thumb.jpg.da3079bfbbbd7a66aded349fde68fa1e.jpg1505301679479-1078656287.thumb.jpg.30b46753b11607e1cb4662ee18b1b4f5.jpg
This cable is an extension cable for the RGBW LED header on the motherboard (as marked on the image below), if you have an RGBW LED strip that does not reach the motherboard.
https://linustechtips.com/topic/834289-motherboard-help/#findComment-10427680
I can plug it that part but it's the side with the 5 connectors that I ant find a place to plug them in
https://linustechtips.com/topic/834289-motherboard-help/#findComment-10427712
