1 minute ago, TheNuzziNuzz said:
Does the Mobo have Bluetooth?
Reinstall the Drivers.
Is it worked good till a week ago
after I noticed its not work I deleted the drivers
now when I try to install the new drivers
the manual finish the install tell me to reset so I do and nothing
I cant see at driver manager nothing
also at driver manager under "Another drivers" I deleted SMS or something
but it was after the problem
https://linustechtips.com/topic/833965-bluetooth-problem/#findComment-10424023
