Kinda off topic, but came across this problem in a physics book yesterday and I cant seem to get it out of my head since im a stubborn person.
I made an handwritten copy to avoid copyrights issues. It says a man doing the plank at a 12 degree angle is 182.88cm tall, weighting 80kg with a 35cm span from head to shoulders and 25cm shoes. They want the normal force applied to the hands and the one applied to the feet.
Basically, my initial logic was that; since his back is inclined 12 degrees, to just cos12 the gravitational gorce but then they want the normal on the hands and the feet. So I'm curious how you would proceed.
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/833762-physic-problem/
Just sum the torques!
.9144F-.5644H=0 -> F=(5644/9144)H
.35H-.9144(80g)+1.8288F=0 -> .35H-.9144(80g)+1.1288H
H≈485.106885 N, F≈299.425116 N
The trig didn't matter. (Yohohohoho!)
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/833762-physic-problem/#findComment-10422363
Yeah, was going to say that, need the torqueseses.
https://linustechtips.com/topic/833762-physic-problem/#findComment-10422408
