Ok so Im cooling a 7700k oc 4.9 at 1.365 Vcore with a Corsair H110i v2, and the temps are a little higher than I,d like but im delidding in a few days so that should help. But I obviously want to get the most out of the cooler as well, so my problem is that the radiator is mounted to the front of a Corsair Carbide 400c and while there are air vents off the side in that spot, the front of the case is covered by a solid piece of plastic, and im thinking this is messing with the airflow into my case. My current set up is like this        //  R  F => Is there a better way? Also if you dont get my diagram // is outside R= Radiator F= Fan and => indicates direction of airflow thanks in advance.
https://linustechtips.com/topic/833415-help-an-amateur/
You can combat the restrictive intake by doing push/pull on the rad
https://linustechtips.com/topic/833415-help-an-amateur/#findComment-10418024
What are your temps?
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/833415-help-an-amateur/#findComment-10418047
18 hours ago, mhernon93 said:
I max out on aida 64 pretty quickly at 91 but usually no more than 85
Gaming temps? Heaven bnchmark temp looping for an hour temps???
Looking around. It seems your temps are on par with others....are you sure that you can't lower the voltage without losing stability?
https://linustechtips.com/topic/833415-help-an-amateur/#findComment-10421248
gaming usually maxed out at 80 on the high side, some games only 75, as for the voltage, Im no overclocking master, and to be honest I didnt test as thoroughly as may be i should have, so no i may be able to drop the voltage a few milivolts. but for sure at 5ghz i wasnt stable under 1.380, but thermally throttled in Aida so I dialed it back to something I knew would work. Anyway, ive done some research and found that short of going push pull ont the rad, thats about as good as im going to get, thanks all for your help.
https://linustechtips.com/topic/833415-help-an-amateur/#findComment-10422675
