My mouse's right button broke and I need to open for repairs but it doesn't have any screws at all, not even behind the pads because they are pure plastic.
Picture:
Hi, I am from Brazil and I pretend on building a Ryzen 2200G build. (to convert to Brazil's currency look up <your currcency> to BRL)
https://linustechtips.com/topic/832582-my-mouse-broke-help/
You're going to need to pop off the buttons by prying them open. That should get you to the internals.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410063
Picture:
Screws are under the glide/feet things on the bottom.  Or at least this is where i've typically found them in other mice in the past.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410077
The pads under the mouse are pure plastic, no adhesives...
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410082
then they are probably under the sticker around the sensor around the middle.  if there are no screws under that buy a new mouse that thing isn't worth the effort.
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410087
So, the 2 front buttons popped out but the rest of the upper part wont move...
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410088
Can you send pictures?
Main PC:
Peripherals/Other:
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410090
As you can see, the 2 front ones detach easily, but the rest wont move.
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410099
Hardware prices here in Brazil are kinda salty, I got this mouse for R$30 on a nearby store, this is the price of a normal mouse around here.
https://linustechtips.com/topic/832582-my-mouse-broke-help/#findComment-10410109
