Hi Everyone.
Came on to ask a simple question.
All Opinions are Welcomed!!!!
You can go into as much DETAIL for your choice as you wish.
This will help me to establish a choice. Tried finding some Youtube Videos. But can't really find any good ones with a clear choice, so decided to ask the Community.
I have a Gaming Headset.
A Razer ManO'War Headset.
ManO'War Headset LINK
It's beautiful on my head. Sound's phenomenal and it allows me to chat with my friends via Discord while Gaming.
BUT...
I can't stand awful Gaming Headsets. It's one after another. I've gone through 3 Headsets in the last year alone. And this headset is getting to this point.
So I was thinking of dropping about $200 on an Audio Setup. Mainly for Gaming. I'm not a Youtuber or Twitch Streamer.
The Audio Setup Gear
- Audio-Technica AT2020 Cardioid Condenser Studio Microphone
- Wanway Microphone Stand + Shock Mount + Pop Filter, Mic Microphone Studio Broadcast Suspension Boom Scissor Arm Stand Holder Etc...
- BEHRINGER U-Phoria UMC22
(Links Below for ALL 3)
Mic
Stand + Holder ETC...
BEHRINGER
Now I ask this question...
Is it better to use a Gaming Headset for Gaming/Streaming/Audio/Chat?
OR
Buy and Setup an Audio Setup for Gaming/Streaming/Audio/Chat?
https://linustechtips.com/topic/832569-choice-in-audio/
Some headsets like the Logitech G633 Artemis Spectrum have perfectly decent mics, but if you play a lot of online games, a stand mic and desktop controller might be worth your while.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10409928
I would buy that mic setup looks nice. My school runs something similar but USB based
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10409945
Just now, MysterioJames said:
@GDRRiley It's been awhile my friend. Haven't talked to you in a few months haha. Thanks for your opinion!!! I appreciate it highly.
Sorry with the amount of people I help I don't remember you. I run a ATH-m30s
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10409957
Lol no I understand haha. You post more on here than I do. I like those headphones you have, they are quite nice. I'm going with Sennheiser, just because I have used there HD 380Pro's before and they were solid.
Don't own a pair. But the HD series of SennHeisers are cheap and won't break my wallet. :D
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10409979
yeah these are 100$ for the slightly new x model. I just replaced the ear pads as my old ones were destroyed
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10409985
I don't think condenser mics are a good idea unless your room is treated. I'm not an expert on mics though and someone else might recommend better.
It's generally better to go for a dedicated audio setup since you can control every single part of your system (mic, preamp, dac, amp, headphones) and if you need to replace one of these for some reason, you don't need to replace your entire headset.
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10410031
1 hour ago, MysterioJames said:
Thank you @bellabichon :D you helped me and I respect your opinion. What headset do you use?
The Logitech G633 Artemis Spectrum! I recommended it from experience. I've had it for three years now and it's still going strong. It also has support for Dolby Atmos now which is nice.
Main PC:
Peripherals/Other:
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10410060
And the actual audio quality of an headset is generally very bad compared to a headphone and a separate microphone.
OP you could look into the pinned post with headphones and also look at shotgun mics, I know it sounds weird to use one of those, but since they are so directional, then it wouldn't pick up a lot of noise from keyboard or people talking that aren't in front of it.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/832569-choice-in-audio/#findComment-10410809
