Bottlenecking info
Go to solution Solved by gbergeron,
3 minutes ago, PeteTeradactyl said:
I am planning on using a Ryzen 7 1700X(hopefully OC to 4.0 Ghz) with a GTX 1080 TI. If I go ahead with my plan, will there be any sort of cpu bottleneck?
No. No bottleneck.
A 7700K would deliver a bit more FPS in 1080p but not a big deal unless you need those few fps for 144 hz etc...
Ryzen 7 pretty good CPU, just make sure to have high frequency memory like 3000 or 3200
No. No bottleneck.
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
https://linustechtips.com/topic/831857-bottlenecking-info/#findComment-10402361
