I just recently replaced my thermal compound on my 1800x (with Artic Silver 5) and was testing it out via aida 64 stress test.  I got some decent numbers (76c on a kraken x62) and then all of a sudden, my pc shuts down; then when it restarts it shows a CPU Over-temp error.  Am I missing something or is 76c too high for Ryzen?
Note: 1800x was OC'd to 4ghz
"Hyper Demon" Build:
Case: NZXT H440 Hyper Beast.  CPU: AMD R9 3900x (cooled by a KrakeX62).  GPU: AMD XFX RX 6900XT Merc 319 Black.  RAM: G.Skill Trident Z RGB DDR4 32GB ram @3600mhz.  Mobo: Asus Crosshair VI hero. PSU: Corsair RM850x.  Boot drive: Samsung 960 evo 500gb nvme ssd.  Game storage: Samsung 860 evo 1TB SATA SSD.  Bulk storage: WD Black 2TB.
https://linustechtips.com/topic/831079-1800x-oc-stability-problem/
1 minute ago, VenomZ_ said:
probably your voltagee
Alright, what should I set my voltage to?
1 hour ago, Dash Lambda said:
Have you updated your BIOS?
I'm not sure, but the first thing that came to mind is the temp offset.
Yeah, im using the latest bios (1501)
1 hour ago, dave_k said:
Voltage under load?
voltage is around 1.35v under load.  Decided to bump it up to 1.4v and up the SOC to 1.1, seems to be working fine now.  Also upped the voltage on my DRAM to 1.5v and reached 3600mhz on the ram.  Will do a stress test to confirm stability.
