I have come to a conclusion that my Samsung 960 EVO 250gb m.2 is causing my pc to have I full shutdown when it hits 34-38c (suppose to shutdown when at 60c for self preservation). If you are asking how I came to this conclusion I did something a little geto and put a fan in front of the thing and benchmarked my pc to simulate gaming.
tests:
1) did a bench with no fan blowing directly on the m.2
result: crash at 35c
2)did a 15min bench with fan
result: no crash
3) held the fan on m.2 for 5min then proceeded to remove
result: crash when drive hit 34c
If you have any questions or suggestions for a fix please do tell thank you all!
https://linustechtips.com/topic/830805-m2-causing-crash-plz-help/
I would return the EVO for another due to possibly faulty probe.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Just now, Tr1ggerfish1 said:
thank you for responding and this is what I was concerned of, but nice to have a second opinion however.
I"m using the 500GB model and haven't experienced any crashing related to temps, but your case is likely due to a faulty probe.
But, I have to say it is strange that the m.2 is saying it's at 34c and shutting down
