Hello, I am new to the pc building world and need some help finding the best gpu for my build. I am using a Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard with a i7 7700 processor. I will be using the computer for hardcore gaming and streaming at high quality. I also will be using the pc for major video editing, 3d modeling, and animation. If anyone could recommend a great reliable gpu, that would be great. I am not on a budget so I am able to spend more money for better quality and more features.
https://linustechtips.com/topic/830203-gpu-help/
gtx 1080 will do 1080p max settings over 60fps or 1440p max 60 +fps in most (or all) things  a 1080ti will do all the things but better. any graphics card will perform about the same in video editing though (via JayzTwoCents)
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/830203-gpu-help/#findComment-10385806
Great, thanks a lot.
https://linustechtips.com/topic/830203-gpu-help/#findComment-10385811
