Fan Control Hub
Solved by W-L,
1 minute ago, Sonicking157 said:What's a good fan hub that would let me control all fan speeds? I on running 2 Corsair SP 120mm, 1 Corsair AF 120mm, and a Corsair H110i.
Your motherboard usually is your best option with the built in fan control options. If you have 3 pin fans though fan controllers such as the NZXT Grid+ V2 or if you want to stick with Corsair link the Commander Mini are good options.
