Help with H100i V2
Solved by tarmacd,
Those fans are not supposed to be plugged into the motherboard directly. They are meant to be plugged into the 4 and 3 pin extension coming off of the cooler block. Plugging them directly into the mobo will not allow the corsair link software to control the fans appropriately. In the configuration you have it setup in, it is possible to run it, but would require more effort. Just unplug the fans from the mobo headers and connect them directly to the cooler with that 3 and 4 pin extension.
Also, so you know it is okay that only one of them is 4 pin and the other is 3, where both fans are 4. It only needs direct PWM control over one, to ramp speeds for both.![]()
Fans connect here
