Motherboard issue?
Solved by Biggerboot,
5 minutes ago, Votivee said:You guys may be right about the port thing, but one thing I forgot to mention is that everything malfunctions at the same time. So I'll loose the lights on my mouse, keyboard, and loose audio all at the same time and they are all plugged into different ports. This makes me believe that it's not on the physical side of things.
Definitely try reseating the CMOS first then, probably the easiest thing to attempt. Bios update after that if you want to be a little more thorough.
It also may be a good idea to try your keyboard or DAC on another computer.
