I have been having issues with my usb devices cutting out, I think I may have figured out why but I cant seem to find all the info I need to check.
I have tried sooo many things and any suggestions I can get from here, toms hardware, and I.t buddies of mine.
I believe I may be overloading my usb chip power wise but cant seem to find the max power draw for my mb nor the power draw of all my devices, I have unplugged unneccesary things and it seems to have fixed the issue so far but I was hoping you guys may be able to help me find the info im looking for.
My mb is a gigabyte ga-x99-ud3
My peripherials
Mouse: logitech g502 Proteus core (not spectrum no rgb just blue)
Keyboard: Razer blackwidow chroma v2 with green switchs (atm default slow color change rgb)
Headset: Hyperx cloud 2 using the inbox usb converter
Peripherial I sometimes plug in
Thrustmaster t flight hotas x
my printer HP photosmart c4180 all in one
Various flashdrives
https://linustechtips.com/topic/827986-problems-with-usb/
My peripherials
Various flashdrives
Try disabling the RGB software for your Razer Blackwidow Chroma. I believe you may be encountering an issue where the RGB polling rate (refresh rate) is overloading your USB controller and is causing other USB devices to be randomly cut out.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/827986-problems-with-usb/#findComment-10363699
