Cpu cooling
Solved by MainDisco,
2 minutes ago, BloodyWaters said:You should be fine with that cooler.
You dont need to upgrade your cooler unless you would do overclocking, which is not possible with your cpu.
I would only upgarde when your cooler is too loud or the cpu would overheat (100°C).
Everything under 80°C is fine.
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning15 -
1
3
7
5
play_circle_filled
Latest From ShortCircuit:
