The cable with the red yellow and blue wire is the CPU fan, should it be plugged into the 4 pin connector that is directly to it's right? It's the amd wraith spire RGB, the empty header was for the RGB ring, I removed it because it was capable of producing a white light. Anyways, it's lableled as cpu_fan so that makes me question if the CPU fan should be plugged in there.
Thank you!
https://linustechtips.com/topic/827020-cpu-fan/
the CPU FAN should be plugged into the header labeled CPU_FAN.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/827020-cpu-fan/#findComment-10353395
4 minutes ago, BabyPCMR said:
Do you see how there is cpu_fan 1 and 2, is the empty one the second one and the one the CPU fan is plugged into the first one?
yes, just plug it into CPU_FAN_1
if you have two CPU fans, you can plug them into both.
Laptop:
https://linustechtips.com/topic/827020-cpu-fan/#findComment-10353426
