force update the firmware?
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10356589
Which OS and CUE version are you using?  I would go and perform all the Windows updates including the optional ones.  Once you respond back, I'll have a better idea of how to proceed.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10363510
Latest version of Windows 10 Home 64 Bit, and CUE Version 2.16.87, and I have already RMAed my mouse once because the whole mouse died sometimes, but it still does that, and I have tried switching though all my USB ports, and everything else I have works fine.
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10364998
Try closing CUE, then going into your Device Manager for Windows, uninstall the Corsair Composite Virtual Input Device under Universal Serial Bus, then restart the OS.  You may need to unplug and replug the mouse after the OS loads.
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10368680
Alright, I'll try that later today and see if it is a permanent fix. When I repair the install it typically lasts for about a week.
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10371450
Now the buttons are just not working in general.
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10392190
  • 2 weeks later...
Does the Corsair Composite Virtual Input still show up in the Device Manager, and does it show any errors?  If the device doesn't show up, try running the repair option for CUE.
https://linustechtips.com/topic/826964-scimitar-rgb-issue/#findComment-10450132
