We are looking to switch out the projectors in our office with LCD TVs and some of the high ups want us to find a wireless solution instead of relying on HDMI cables.
I've tried to convince them of the impracticality... no dice.
I've done a bit of preliminary research and there doesn't seem to be too much out there that support both Mac and PC for full desktop aside from either an IOGEAR GW3DHDKIT or GUWAVKIT4B.
Any ideas, or should I push the cable issue again?
https://linustechtips.com/topic/826832-wireless-pc-to-tv-hdmi-solution/
wired is a better option far as I remember as there isn't many wireless solutions, and even some of the "wireless" ones need cables, so yea I suggest pushing wired, by pointing out that it will be cheaper, more reliable, quicker to set up and not a pain in the arse when it doesn't work, as the wireless will be a pain in the arse to set up in all likelihood. Pretty much think of it this way, if you can you hard wire every PC you have to the router as it is easier to manage and is much less likely to drop and not work, as you have a "bad wifi signal" which will happen for you, probably when you need it not to the most
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
1 minute ago, Dlog said:
That's what we got right now, but unfortunately we also have a number of Mac users who need to be able to cast their screens as well.
Probably this unless anyone has some sort of miracle device. HDMI is cheap and platform agnostic.
there are definitely wireless HDMI solutions out there, but they are usually kinda pricey, you can get something like this and just run it over an access point, but yeah, pricey
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
Home PC:
Work PC:
or you could use RDP
Home PC:
Work PC:
still needs cables between the RDP PC and the TVs also I would suggest teamviewer over RDP for this task, as RDP only shows a screen similar to the log in screen on the PC your controlling, which is an issue when you are using it in a meeting
