front panel jack not working
try using passthrough audio if you have a gpu
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, dweed2 said:
im sorry noob question but how do i do that?
So usually on monitors there are two ports labelled audio in and audio out
use an hdmi or DP cable to connect the PC to the monitor
then plug the earphones into the audio out port
Full Specs
Helios EVO (Main):
Delta - Laptop
i was using a dvi and it electrocuted my earbuds a bit is this because of my choice of wiring or is it not an audio port,,, btw my monitor only has the one audio looking port
