Help with finding old Logitech drivers.
Go to solution Solved by looney,
In the logitech gaming software you can select where the programs stores your mouse settings (either on the mouse memory or on the pc)
Try switching to the pc based version as that will give your more macro options.
http://forums.logitech.com/t5/G-series-Gaming-Mice/g600-rapid-fire-macro/td-p/896376
So, this post on the Logitech forums shows that setting up a rapid click macro can be done. My current drivers will not do so, and I need to find the drivers for this. I have a Logitech G600.
https://linustechtips.com/topic/82522-help-with-finding-old-logitech-drivers/
Respect the Code of Conduct!
>> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team <<
>>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<<>>LTT Speed wave<< | >>LTT Communies and Servers<<
Why thank you, oh lord of schnitzel.
