Raspberry Pi Project
I have always wanted to do a Raspberry Pi project, and I think now is the time as I have a monitor, keyboard, and mouse I am not using but all still work.  I would like to turn it into a Linux distro machine (albeit not a very fast one).  I have it on my laptop, but I rarely use my laptop at home; instead, I'll be making a Lubuntu machine for at home.  My 'parts' list includes just a kit, which can be found here, as well as a HDMI to VGA adapter.  I plan to mount the RP to the back of the monitor using adhesive pads that I already have.  Just a few questions-
  • How easy will it be to install Lubuntu onto the machine?
  • Will the Pi be fast enough for web browsing and watching videos?
  • Do I really need a case and heatsink?
https://linustechtips.com/topic/825210-raspberry-pi-project/
The case and heatsink are recommended as they reduce the risk of ESD or overheating. Web browsing is pretty good, watching videos is moderately okay.
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333047
Which Raspberry Pi model do you have?  What resolution do you watch them at?  The monitor I'm using it with is 720p so I do not know if that'll make a difference.
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333070
I tried to use my own one for browsing. It' okay not the best.. Now I'm using it as my OpenVPN server and NAS. :)
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333090
2 minutes ago, lilbman said:
Which one do you have?
I believe Model B.
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333099
3 minutes ago, lilbman said:
The Raspberry Pi 3 Model B?
Yes. :) I forgot to mention. When I bought the first one, it overheated. :( Amazon sent me another one and refunded me for the first one. So make sure you have a heatsink with yours, if you're going to use it as daily driver. Also, get a case for it. It'll look nice. :D
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333119
I have the Raspberry Pi 3 model B, watching them in standard view on YouTube(720p60 if I recall correctly)
Edited by Crunchy Dragon
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333242
Good to know, guys-thanks for the responses!
Would it be better to just buy something like an Intel NUC and use that? I don't want to spend too much money on it as it won't be a daily driver, but it will be nice for occasional use.
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333806
raspbian is equivalent to lubuntu in terms of being lightweight and simple.
you would be better off with a tablet or chromecast
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333889
I don;t believe you can use a Chromecast with a keyboard and mouse and use it as a general web browsing machine.  Good to know that Raspbian is light enough for use.
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10333939
A NUC would run a lot better and faster than a Pi. If you're looking for a more budget-oriented PC, I'd recommend the Pi. If not, go for the NUC
https://linustechtips.com/topic/825210-raspberry-pi-project/#findComment-10334151
