Recently I've been getting bluescreens and tons of games crashing on me including PUBG, Rainbow Six, CS:GO, Euro Truck Sim 2. I have no clue if it's hardware or software.
Current Specs:
i5-4690k, 3.5GHz w/ Hyper 212 EVO
Gigabyte G1 Gaming GTX 1070, 1785 MHz and 8008 MHz Memory Clock
ASRock Z97 Pro4 Motherboard
Crucial Ballistix Sport DDR3-1600 RAM (4x4GB)
Corsair CX650M
WD Blue 1TB, PNY CS1311 240GB SSD
So a few months ago I upgraded my PC and I started experiencing these problems quite recently. My old PC was basically the same, but with a GTX 760 and 8GB of RAM. It ran flawlessly.
When I got PUBG, it consistently crashed and I tried a bunch of fixes online and NOTHING worked. Then, I reinstalled Windows and the crashing still happened. I began to get blue screens and other games started to crash, even games I've never had issues with.
I've tried:
chkdsk
Windows Memory Diagnostic Tool
Windows Driver Verifier
sfc /scannow
At this point it's getting worse and I'm worried if it's a hardware issue.
Any help is appreciated, thanks.
https://linustechtips.com/topic/825206-need-help-troubleshooting-issues-with-pc/
Use BlueScreenView to tell us which error you're getting.
http://www.nirsoft.net/utils/blue_screen_view.html
Current Build
Successful Builds
2 hours ago, noticemerage_ said:
The three most common are:
kernel_security_check_failure
unexpected_store_exception
system_service_exception
kernel_security_check_failure: You might have corrupt files and should try to replace them (system file checker), also update if you havent done that.
unexpected_store_exception: Update hardware drivers, try update your antivirus.
system_service_exception: Try updateing drives for your hardware, remove hardware to find where the issue comes from. If you can try replace the hardware if you got spare parts to try.
I'm not a expert but I do know how to use google. From this I could only tell you one thing for sure, try update your drivers and windows man :P
Back-end developer, electronics "hacker"
