I believe as long as the repair doesn't say anything about resetting or data loss, you shouldn't lose any data.
So just run the repair and then everything should be fine.
I believe the whole thing is a driver issue, although windows 10 should run normally and then update drivers casually on the side, your case seems like it wasn't able to do that. So i guess run the repair and let him work.
