Hey all,
I have recently built a Ryzen 5 1600 machine and I am pretty worried with the temps with the stock cooler. I idle around 48C OC'd to 3.8Ghz at 1.36V. I am measuring temps in BIOS, Asus AI suite and HW monitor. Is the offset thing still in effect? Or are the monitors showing the correct temperature. When i built it i was idling at 50C on stock (one reason was that an auto the vcore spiked to 1.40v), I re pasted (with Thermal Grizzly Kryonaut) and seated the cooler and got some improvement but 2-3C at most, also the LED AMD logo doesnt work so I think there might be the possibility i received a defective cooler. I am thinking of buying an H100i V2 but wanted to postpone the buy in 1-2 months but the temps are acting up and it gets me worried.
Any takes on this?
//Case: Phanteks 400 TGE //Mobo: Asus x470-F Strix //CPU: R5 2600X //CPU Cooler: Corsair H100i v2 //RAM: G-Skill RGB 3200mhz //HDD: WD Caviar Black 1tb //SSD: Samsung 970 Evo 250Gb //GPU: GTX 1050 Ti //PSU: Seasonic MII EVO m2 520W
https://linustechtips.com/topic/824607-ryzen-temperature-offset/
Just now, RKRiley said:
The 1600 doesn't have the temperature offset as far as i know, that's only 1700x and 1800x's.
Also the stock cooler for the 1600 doesn't have any led's, so its not defective in that sense.
Thanks for the input. Actually it does it worked once. then died.
No it definitely doesn't have any led's xD otherwise there'd be an extra(i think) 3 or 4 pin plug attached to it to power the led(s) on it.
No it definitely doesn't have any led's xD otherwise there'd be a 3 or 4 pin plug attached to it to power the led(s) on it.
Oh I dont mean RGB leds :P Just a White led lighting up the AMD Logo :P
48 minutes ago, Damascus said:
Those temps are OK but meaningless.  We need load temps.
under AIDA64 stabilty test for 35min it reached 80C
