iMac Problem with Image
Go to solution Solved by Daniel1,
On 8/27/2017 at 11:54 AM, DarthSmartt said:
you're welcome
My friend found out it was his hard drive from the iMac.  He is getting his hard drive replaced.
I am trying to help a friend out that has a problem with his iMac.  Recently he tried logging in to his iMac and it was lagging.  Once he logged into his iMac it showed a black screen.  He waited a few minutes for the iMac to load in and it eventually shows the graphic user interface such as the task bar.   He tried clicking his hard drive and other programs; it didn't load the programs or the hard drive.  My friend eventually wipes his hard drive storage and clean installs the latest iMac os.  Yesterday it showed this image as he was booting into his iMac.  What does all of this mean?  Thanks if you can help.   rueHoez5H2x0ceMohZZODXan_V0pV2JsGMxL04ZLoZXnNcy3j76_Qu_xrwFBTTN5nM_CWFyJevmlnJWhkPXflBeOJw4rEbg9vWRqyDwvv3mPPysvVqqL6fMO1RnovGS2o-1RGFkycweFB90cSY5pnrJBznYywGqr0M36H3eUy_xjIEmgnvuF0ttNnPXNMvvj-Ge8ynE6yxPL2Ik71V5CJkd8LAdljEDVpKNum7kzE6C5OCbIE_TpgHC_iwm7Wnotxx75SoIIE6qSz4I43hzJVBzuglEoTc97_0luaKdZT43reGmcrzEEsL26lDZlURPLYFQ-r1UQQztc340fQWY1ow_6WVz0zs0EBkWIbcCbxwSBho7gTDw6qCQJyP9785CFshQ5DIqNGSp6jixPU-QBxd4yoTHPGItiB1yJ8CnkkS01s7cJZNtWolmwRCsWVtL6cJfbX-VW97OvgDFZRSnyzlRDC-kg-RoNXaCX_wAicU1yj1fhveZInHtERj7eZb3JmgWNijidFon4zszHkecZwEtQgvTAscQZ-Q2o757mvvzqibhMEJ4UUoCH14dauCeHo2_5dqRxCEWUXcnKLZlKRCl_pdUgcVc3yG7-z8YhtlFgKJXC9qGq=w1210-h908-no
https://linustechtips.com/topic/824238-imac-problem-with-image/
I had this issue with a mac once after updating to sierra. If you can get a hold of another mac follow this tutorial and reinstall Sierra. If he has a time machine backup try restoring to an old backup before Sierra. If this doesn't work, than you most likely have a bad hard drive or bad ram. Possibly some other component. If my steps don't work, then I would take it to an apple store.
Build:
Intel Core I7 6700k (clocked to 4.6ghz)
Patriot Viper 3000mhz ddr4
ASUS maximus 8 hero (I hate this mobo)
Evga gtx 1080 superclocked
250GB Samsung 850 evo
2tb WD Black 7200rpm
Ek watercooling kit a240g with 360 expansion pack
Primochill Vue Red fluid
Corsair Graphite 600t (white)
You thought "Gee, Donald Trump sure has a great build!"
https://linustechtips.com/topic/824238-imac-problem-with-image/#findComment-10322879
This might work, if it doesn't, i think it's because you have a kernel faliure, which means, in simple terms... you screwed. It means the os is really curupted and broken, and there is really no real way to fix it. I had this problem on a mac before. Sorry.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
https://linustechtips.com/topic/824238-imac-problem-with-image/#findComment-10322903
i had the same problem before updating to sierra, if you go back into time machine a while before the update it will work. if you reinstall sierra it will also work.
Build:
https://linustechtips.com/topic/824238-imac-problem-with-image/#findComment-10322914
On 8/20/2017 at 11:05 AM, Dan1 said:
Yesterday night my friend used the time machine on the iMac and went back.  His iMac is working good again.  Thanks for all the help.
you're welcome
Build:
https://linustechtips.com/topic/824238-imac-problem-with-image/#findComment-10359311
If it was the hard drive, he wouldn't be able to boot from time machine though.
Build:
https://linustechtips.com/topic/824238-imac-problem-with-image/#findComment-10392557
1 minute ago, Dan1 said:
Everything is good now.
cool cool
Build:
https://linustechtips.com/topic/824238-imac-problem-with-image/#findComment-10393345
