If you have Win8 or newer, shutdown doesn't really shut it down. There will be trace background software running. And if this is pretty new, contact Asus directly. Faulty batteries are a thing, but warranty only lasts for 6months.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/823189-laptop-battery-draining/#findComment-10313960
i'm currently running windows 10 creators update home version. as i know about windows fast shutdown is not a complete shutdown. And i already contacted asus and they had changed by laptop battery.
https://linustechtips.com/topic/823189-laptop-battery-draining/#findComment-10316795
So it's prolly the battery that has a problem. Try checking the Fast Startup as well and I recommend you to turn it off.
Daily drivers:
- HP Elite x2 1012 G2: Intel Core i7-7600U, Intel HD Graphics 620 + Aorus Gaming Box GTX 1080 eGPU, 16GB LPDDR3-1867, 256GB Toshiba NVMe PCIe 3.0 x4 SSD + 128GB Toshiba Exceria UHS-1 U3 MicroSD, 12.3" 2736x1824 + HP Pavilion 22cwa Monitor 21.5" 1080p IPS, Windows 10 Pro 64-bit
- LG V20 (H990DS): Qualcomm Snapdragon 820 (ARM-based), Adreno 530, 4GB LPDDR4, 64GB eMMC UFS 2.0 + 64GB SanDisk Extreme UHS-1 U3 V30 MicroSD, 5.7" IPS LCD 1440p + 2.1" 160x1040, Android 7.0 (LG UX 5.0)
Other devices:
- Lenovo IdeaPad Y400: Intel Core i7-3630QM, NVIDIA GeForce GT 750M SLI, 16GB DDR3-1600, 120GB Kingston mS200 mSATA SSD + 1TB HGST Travelstar 7K1000 7200rpm 2.5" HDD, 14" 768p, Windows 10 Pro 64-bit + Ubuntu 16.04 LTS 64-bit [retired]
- Dell Venue 11 Pro (7139): Intel Core i5-4300Y, Intel HD Graphics 4200, 8GB LPDDR3-1600, 256GB SanDisk X110 M.2 2260 SATA3 SSD, 10.8" 1080p IPS, Windows 10 Pro 64-bit + Ubuntu 16.04 LTS 64-bit [retired]
- Acer Iconia W4: Intel Atom Z3740, Intel HD Graphics, 2GB DDR3L-1033, 64GB Samsung MCG8GC eMMC, 8" IPS WXGA (1280x800), Windows 10 Home 32-bit
- Asus ZenFone 2 ZE551ML: Intel Atom Z3580 (x86-based), PowerVR G6430, 4GB LPDDR3, 64GB eMMC, 5.5" IPS LCD 1080p, Android 6.0.1 (Asus ZenUI)
- New Nintendo 2DS XL
https://linustechtips.com/topic/823189-laptop-battery-draining/#findComment-10318282
No battery can't be faulty because i recently replaced it with a new one. And currently i'm doing fresh installation of windows to check whether it's windows problem,driver or fast startup.!
https://linustechtips.com/topic/823189-laptop-battery-draining/#findComment-10325418
