Hey guys!
first of all im a newbie on the forum So uhm hi i guess :P
but now let's get to my problem wich is messing with my head really bad.
first of all the specs:
corsair rm750x psu (don't know for sure if its a rm but it is 750 watts)
i7-4770(non k)
msi h97 gaming 3 mb
msi geforce 1080 gaming x (factory oc)
32 gb corsair 1600 mhz ram
samsung 750 ssd
a old 2tb mech hdd 5400 or 7200 rpm dont know for sure (game drive) (issue?)
so here is the problem:
in games like gta v or pubg or even beam ng and also rust or other games
my fps does not come above 70 rarely above 50 even!
my cpu usage is for example is 50 to 70% MAX (70% is really rare) and gpu is around 30 to 50% in gta v
in beam ng its even worse,
both the values are around 30% constant nothing more
this thing is really messing with my head
troubleshooting i have done:
Reinstalled windows (2 times 1 time because my ram died ;( )
installed latest nvidia driver also several times
reinstalled most the games
i really tried every thing i knew
and i know in really cpu intensive games my i7 is not going to be good enough but 40 fps on gta v come on even my gtx 770 reached 80 fps :S
I really hope someone can help!
https://linustechtips.com/topic/823019-headbreaking-perfomance-issue/
check gpu usage, temps and clockspeed in msi afterburner
pugb is very badly optimized.
turn off that AA
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
  • 2 weeks later...
So ehm yeah hi again,
sorry for the late update i had a holiday without internet (i know, hate me right?!)
So i went to testing and these are the results:
GTA V
temps:
GPU: around 50 to 65 degree C depending on scene/gameplay
CPU: stable 50/55 degree (some days 75 degree when the sun was on my room a hole day and my room was around 45 degrees (did not impact performance tho))
usage:
CPU: 50/75% (again depending)
GPU (55/100%) the 100% only occured in cinematics not in gameplay
Clockspeeds
CPU (non k so not overclocked) 3699 mhz/ 3700 mhz wich i find kinda weird cus my cpu is rated to 3.9 ghz boost wich it never reaches only in aida 64)
GPU stable oc: core/2050 mhz memory 5525/11050 mhz
fps (120 in benchmarks 40/60 in game)
ARK
is around the same only 40 fps on high/medium
but now the weird thing:
cinebech r15
my friend scored 600 something on cpu and
99 fps on open gl
his specs: i5 7400 no k
and a msi ... ... ... gtx 1060 (model and oc not known)
and now my score:
with the i7 and 1080
CPU: 850+- wich looks fine to me
but now the weird one
open gl: 93 fps
and again the problem: gpu usage 40/50% during the test
iam seriously headbroken at the moment and i seriously do not want to spend 1000+€ just to find out it changed nearly nothing
and yeah the upgrade will be around 1000€:
new mobo
new ram
new cooler
new cpu
seriously i need help!
hope someone can help me!
peace!
