Please help unkown driver
Go to solution Solved by RileyTheFox,
2 minutes ago, MrMcArtur said:
Ok so ive tried everything to connectt my ethernet but it doesnt work. Ive figured out the issue. Outdated ethernet driver. The issue is I dont know which driver it is because it says unkown (in device manager) I also dont have internet so I cant download a driver identifier program. (Also I cant do the offline scan becasue the computer with internet is the only windows i have)
Does anyone know which driver I have to install?
My motherboard is MSI h270 tomahawk arctic
Please help im desperate
Go to MSI's web page on another PC, it can even be in one of those Internet cafes.
Go to the support and downloads section. Download the Ethernet driver for your motherboard and put it on a USB stick. Go to the PC having problems and then run the setup.
https://linustechtips.com/topic/822093-please-help-unkown-driver/
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
Im having trouble finding it. Can you please post a link of where i can download it
