Just now, JacTech17 said:
im using the speed fan app to control my fans which only affects my CPU fans and 3 RGB radiator fans, but I still have 5 3pin nzxt fans 3 140 and 2 120 connected to a fan hub power splitter and wanted to know is there a way to control the five nzxt fans
What hub are you using exactly?
https://linustechtips.com/topic/821991-fan-control/#findComment-10299715
the one that was included with my nzxt source 530 case a 3pin 10 port fan hub
You won't be able to control the fans with that, it's only a powered hub. Your going to have to either have the fans in groups using splitters on the motherboard or get a fan controller like the NZXT Grid+ V2 since they are all 3 pin fans.
https://linustechtips.com/topic/821991-fan-control/#findComment-10299744
