Ryzen 1700X issues
1 minute ago, NBPC said:I have just cleared cmos and reseated the RAM in the slot closest to the processor , I got this message on startup
please enter setup to recover BIOS setting
when RAID configuration was built ,ensure to set SATA configuration to RAID mode. I entered bios setup and exited again not changing anything
booted to windows and I just got 1508 !
Thank you so much Man !! But what did I do wrong was it the overclock or the voltage ? Because I would really like to overclock this to 4.0ghz
It might be the voltage. You can try overclocking again although I recommend doing it slowly and incrementally testing as you go taking notes on performance at each step. If you see the performance drop again you can reset the CMOS, keep a close eye on your actual processor clock speed (as read by HWmonitor or AIDA64, not task manager). If the clock speed is dropping down then it could be the overclock is unstable and the system dropping to a low power state to remain stable. You might be able to resolve this with some trial and error by using lower voltages and adjusting the load line calibration etc. If the performance is dropping and the clock speed isn't then there might be something else going on although it would be hard to identify the root cause without more data.
Good luck.
