Is it better to stick with amd for cpu and gpu or is hybrid better like intel coy and amd gpu or vise versa? Ive heard competing talk that hybrid is btr but I'm about to build a new box after losing mine in louisiana floods 3 days after I bought my home. Its mostly for gaming but I'm stuck a little on so,e co,polenta because it'll be my first liquid cooled system and ive always had amd stuff now I'm curious if intel gpu is btr. Esp with so little I can find on new vega nova gpu that hasnt cone out yet.
https://linustechtips.com/topic/821563-hybrid-or-not/
Neither is "better". It doesn't matter.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/821563-hybrid-or-not/#findComment-10295168
With an AMD GPU, I doubt it makes much of a difference (Unless you're worried about losing a tiny amount of FPS). For NVidia GPUs, you will find that they were optimized for Intel's ringbus design and will suffer on just about any AMD CPU, but this does not apply as you're interested in an AMD GPU.
Edit: Also the embargo on AMD Vega reviews ends at midnight/tomorrow if I am not mistaken.
https://linustechtips.com/topic/821563-hybrid-or-not/#findComment-10295208
