Hey,
I was playing CSGO today and all of a sudden my computer shutdown, I unscrewed it to find it very warm. I tried to power back on but the fans spin for a second then turn off, the power button stayed lit up even though I was holding it to shut down. I got past this issue by doing the paperclip test and now my system runs alright, however, my GPU is not working. I've cleaned the ports and resetted it a couple dozen times but nothing. The fans are in a loop of mildy starting and stopping (I'll upload a video), and yes the 2 power cables are attached to the GPU (2x 6 pin). It's really weird since I tested the 6 pins and they work fine and onboard graphics works aswell.
The GPU is a EVGA GTX 970.
https://linustechtips.com/topic/821510-need-help-gpu-not-working/
