So I'm having problems with my rx 580 armor for the last 2 or 3 months because of the heat and noise it produces. I've ordered a accelero IV and I was thinking on changing the cooler.
But after undervolting the card (not sure if I did it properly) and activating the amd chill feature the noise and heat dropped down a bit. Now I don't know what to do. If I keep the cooler or change it and void the warranty. Also why does the gpu usage never past 16 while gaming?
What do you guys think of the undervolt?
https://linustechtips.com/topic/821491-rx-580-problem/
6 minutes ago, VerVistas said:
With chill of in current config It reaches 82c on furmark benchmark and it trottles a bit.
Furmark is an unrealistically HOT stress test. My fury just wont go over 76c in ANY game, but if I open furmark I hit 80c and throttle 100mhz or so.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/821491-rx-580-problem/#findComment-10294521
Well on valley bench, in high quality with aa in x2, for the stock setting it reaches arround 72c but it's really loud, and it trottles a bit.
If I change the max temp on wattman to 85, and put the max fan target to 2000rpm it's quieter but it reaches 80c.
I kept the fan target and undervolt the 2 final stages to 1000mv, and still it reaches arround 76-78c after a few minutes. It's allways on 1366mhz tough. Is it normal to have allways 16% gpu usage?
I did all testes for about 3-5 minutes.
https://linustechtips.com/topic/821491-rx-580-problem/#findComment-10294833
What a piece of shit.. seriously.
My Fury is a 300 watt card and i never break 70c even with low fan speed pushing more volts and an OC.
I had to add music in my video's because you can hear nothing in the background but a quiet airflow sound.. and i'm running an x58 system with a MASSIVE OC.
MAD-BOX Ryzen 1600X - ASRock X370 Killer SLI - Sapphire R9 Fury NITRO+  -Fried it... RIP
Xeon e5640 4.35ghz, CoolerMaster Seidon 240V, ASUS P6X58D-E, DDR3 8GB 1636mhz CL9, Sapphire Fury Nitro OC+, 2x Stone age storage @ 7200RPM, Crucial 960GB SSD, NZXT S340, Silverstone Strider Gold Evolution, Steelseries RIVAL, Mechanical Metal keyboard, Boogie Bug Aimb mouse pad.
https://linustechtips.com/topic/821491-rx-580-problem/#findComment-10294872
